I have a drawing (second actually) that started deselcting objects in viewports. I tried deleting all hatches. If i maximize the viewport the objects remain selected. If I unlock the viewport then the objects remain selected. Is there a solution for this?
I just tried copying all entities in the drawing to another new drawing and the panning works. Dont know for how long but it works for now. One cant keep making new drawings and copying into them.
I also found out that if pick 101 or more entities that the entities remain selected when panning even though they are not visibly selected until zooming in or out or executing a command. so if you select more than 100 entities then they are deselected.
for a temporary work around. go to options/selection tab and set Object selection limit for display of grips to 1
if you do that then as long as you select at least 2 entities before panning they will still be selected eventhough not visibly until zooming or initiating a command.
Hope that helps someone figure out exactly what the problem is.
I'm not sure about the "visibly selected" term, if you mean that grip-points is the mark for "visibly selected" then this is wrong, sorry.
Selected means nothing more then in a selection set and you can see that on the entities with the highlight-effect, in your release that's something like a bit lighter and dashed.
Number of Grip-Points on the objects (and if they are created on display or not) is limited (out of performance reasons) with the setting you showed in the options (or sysvar GRIPOBJLIMIT).
Back to your original question: do just the grip-points disappear or are previouly selected objects really unselected?
- alfred -
Solution |
