AutoCAD 2010/2011/2012
Active Member
0 Kudos
Post 1 of 18
Opening multiple DWGS, always opens a new application
5529 Views, 17 Replies
08-19-2010 07:56 AM
Just got AutoCAD 2010, its not bad but has a issue that bugs me.
If i have one file open, and go to my desktop (or any folder) and double click a file to open it... it opens the new drawing in another instance of AutoCAD.  Id rather have it open in the same instance to ease of use and so it wont tie up mulitiple network licenses.
Can someone help?
In Windows Explorer select Tools then Folder Options. On the File Types tab find DWG in the list and make sure it is set to open with AutoCAD DWG Launcher and not acad.exe
Distinguished Mentor
6 Kudos
Post 2 of 18
Re: Opening multiple DWGS, always opens a new application
08-19-2010 08:06 AM in reply to: uncisbest
Instead of going to desktop, use yellow folder on menubar to open more dwgs.
Active Member
0 Kudos
Post 3 of 18
08-19-2010 08:12 AM in reply to: uncisbest
no, id rather not do it that way.  I get DWGs emailed to me and i would rather double click inside of Outlook instead of saving it somewhere then going into AutoCAD and finding it thru the open command.
AutoCAD 2009 would let me do it the way i want to...
25 Kudos
Post 4 of 18
08-19-2010 09:31 AM in reply to: uncisbest
Is your SDI system variable set to 0?
Is your Taskbar system variable set to 0?
Active Member
0 Kudos
Post 5 of 18
08-19-2010 11:14 AM in reply to: Johneng
im not really sure what those are. haha
But ill try to find them and look em up.
Active Contributor
0 Kudos
Post 6 of 18
08-19-2010 11:37 AM in reply to: uncisbest
Keep in mind some third party software will change your settings to disallow opening more than one file per instance of autocad and will either close the existing drawing before opening the intended drawing, or open another instance.
25 Kudos
Post 7 of 18
08-19-2010 11:45 AM in reply to: uncisbest
Type SDI then enter on the command line you should get the following command line response. Enter new value for SDI <0>:   If your value is <1> type in 0 and then hit enter.
do the same with taskbar. Type in TASKBAR then enter on the command line you should get the follwoing command line response.  Enter new value for Taskbar <0>:  If your value is <1> type in 0 and then hit enter.
Active Member
0 Kudos
Post 8 of 18
08-19-2010 01:21 PM in reply to: Johneng
Ok i set everything to 0 and it still opens multiple ACAD applications.
76 Kudos
Post 9 of 18
08-20-2010 03:48 AM in reply to: uncisbest
Active Member
0 Kudos
Post 10 of 18
08-20-2010 05:37 AM in reply to: M_Hensley
Thank you very much M Hensley, that fixed it!
