AutoCAD Forum
Open a closed project
5 REPLIES 5
347 Views, 5 Replies
Autocad 2011
I accidently "closed" a project and it dissappeared from my project tree.
How do I get it back to the project tree?
5 REPLIES 5
Alfred.NESWADBA
what product exactly do you have? Because AutoCAD itself - without any application or as vertical - does not have a "project tree".
Start command _ABOUT and you'll see what product you are running.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
ACADE 2011. Version 2.1
On the left side of the window there is a list of "Projetcs" in the "Project Manager".
You right click on a project to "Activate" it when you want to work on the drawings in that project.
There is a lso a "Close" selection...I hit that by mistake and that project is no longer visible.  How do I make it visible again in the Project list?.
Alfred.NESWADBA
Well, you are using AutoCAD Electrical, so this forum >>>here<<< is the place where you should ask the question.
Good luck, - alfred -
Alfred NESWADBA
Is this a hard question to answer??
pendean
Since you are posting in the wrong forum, yes it is, plain AutoCAD where you are posting doesn't have that feature.
Repost in the correct forum for your product here: http://forums.autodesk.com/t5/AutoCAD-Electrical/bd-p/38
”Boost
