AutoCAD 2010/2011/2012
Member
edithadudley
Message 1 of 7 (2,213 Views)
One or more objects in this drawing cannot be saved to the specified format
2213 Views, 6 Replies
01-29-2013 02:03 PM
Users: Windows 7, AutoCad 2011 update 2 applied
Windows Server 2008 r2
Data stored on a network share
Network licenses on a separate server
My problem started when we moved all of the users data to a new Windows 2008 r2 server.  Searching and file navigation was slow so we turned on Windows Search service.  Greatly improved network searches (users do content as well as file name searches).
Then Autocad started having errors when trying to save or create dwf files.  The error "One or more objects in the drawing cannot be saved to the specified format.   The operation was not completed and no file was created."  Users can save the drawing to the local drive without the error.
Turning search off corrects the save issue but also slows searches .
Know of a way to accommodate both?
Thank you,
Edie
*Expert Elite*
braudpat
Message 2 of 7 (2,172 Views)
Re: One or more objects in this drawing cannot be saved to the specified format
01-31-2013 06:37 AM in reply to: edithadudley
Hello
Curious !  Are you using only AutoCAD ou AutoCAD LT ?
For example have you some AutoCAD MAP ou AutoCAD CIVIL running too ?
Because with MAP or CIVIL and the drawings Group and the Lock Feature at the entity level
some strange things could append in a mix environment ...
Bye, Patrice
Bye, Pat
Member
edithadudley
Message 3 of 7 (2,151 Views)
01-31-2013 01:22 PM in reply to: braudpat
We are only using Autocad
Thank you,
Edie
*Expert Elite*
pendean
Message 4 of 7 (2,141 Views)
01-31-2013 02:27 PM in reply to: edithadudley
That's a file content error and has little to do with moving files from one server to another. Someone somewhere opened or is using AutoCAD 2013, or you received files from someone using R2013 and/or a vertical version of AutoCAD.
AEC content in a file will do that if you are running an AutoCAD version not able to create/edit them.
http://www.cadforum.cz/cadforum_en/one-or-more-objects-in-this-drawing-cannot-be-saved-tip7463
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
edithadudley
Message 5 of 7 (2,097 Views)
02-04-2013 12:56 PM in reply to: pendean
Everyone's settings are the same.  Save as: AutoCad 2007/LT drawing.
The problem goes away when we turn off indexing (Windows search service) on the Windows 208 r2 server
New Member
samcappelle
Message 6 of 7 (2,073 Views)
02-06-2013 12:43 AM in reply to: edithadudley
I do have the exact same problem. When I stop the Windows Search service on our Windows Server 2008 R2, no more error messages appear. Is there a solution for this problem, as we do want to enable the Windows Search service for indexing.
Sam
*Expert Elite*
pendean
Message 7 of 7 (2,049 Views)
02-07-2013 05:55 AM in reply to: samcappelle
There appear to be several obscure posted fixes I found through a Google search, and one specific for one of you in this thread, here is the first of many:
http://community.spiceworks.com/topic/298813-autocad-2011-errors-saving-to-indexed-windows-2008-r2
Help yourself to the others if that's not it.
Announcements
Need installation help?
