AutoCAD 2010/2011/2012
0 Kudos
Post 1 of 19
One or more objects in this drawing cannot be saved to the specified format
21275 Views, 18 Replies
11-16-2011 06:44 AM
In 2011 every so often I get this error "One or more objects in this drawing cannot be saved to the specified format. The operation was not completed and no file was created." This happens and I just go and click file or regen and sometimes it just saves the file other times it does not. Anybody know what causes this or why it happens.
594 Kudos
Post 2 of 19
Re: One or more objects in this drawing cannot be saved to the specified format
11-16-2011 08:00 AM in reply to: ezwingman
command: EXPORTTOAUTOCAD and see if it'll fix the problem.
0 Kudos
Post 3 of 19
11-16-2011 08:14 AM in reply to: Patchy
Unknown command in 2011 that I have.
*Pro
118 Kudos
Post 4 of 19
11-16-2011 08:21 AM in reply to: ezwingman
try either;
-exporttoautocad
or
aectoacad
hth
0 Kudos
Post 5 of 19
11-16-2011 08:52 AM in reply to: ampster
That short version of the command was there and worked, but I really wanted to know why I get the error.
Active Member
0 Kudos
Post 6 of 19
03-22-2012 03:59 PM in reply to: ezwingman
The commands listed seemed to work, but no file was created.  I tried all of the other suggestions posted here to no avail.  Also, when I get this command, I can't Ctrl+C my drawing--it says "copy to clipboard failed".
I think when I had this problem before, it saved when I closed cad, even though it said it didn't.  (I didn't try that this time as weird things happened when I ran an audit that I didn't want to save.)
1,588 Kudos
Post 7 of 19
03-22-2012 04:03 PM in reply to: jbhammerton
AEC content in a file will do that if you are running an AutoCAD version not able to create/edit them.
Exploding these using AECTOACAD or -EXPORTTOAUTOCAD commands and converting them to plain AutoCAD objects is a popular cure for those using plain AutoCAD but tapping DWG files from verticals like ARCH or CIVIL3D etc.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Distinguished Contributor
4 Kudos
Post 8 of 19
02-13-2013 10:54 AM in reply to: ezwingman
Renaming the directory the drawing is saved in while the drawing is open will also cause this error. Doing a "saveas" to something else fixed it for me.
Civil 3D 2015
Windows 7 Pro (64bit)
Intel Xeon W5580 @3.20GHz
12gig RAM
NVIDIA Quadro 600
Active Member
4 Kudos
Post 9 of 19
04-25-2013 05:41 AM in reply to: ezwingman
This is an old thread but I thought I should add another solution to the mix.
We are running a Novell Network environment with specific allotments of space for the CAD users.
That exact message appears when the user runs out of space on the network file server and tries to save a drawing there.
Free up space on the file server, the error message goes away and allows you to save.
Hope this saves someone a little time and head scratching.
-steve
Member
0 Kudos
Post 10 of 19
07-22-2013 06:53 PM in reply to: ezwingman
Thanks greatly for that.  Was exactly my problem too!
:smileyhappy:
