AutoCAD Forum
Objects, dimensions not displaying as per settings,..
2 REPLIES 2
477 Views, 2 Replies
Hi,.
I have attached a AutoCAD Drawing with this message,.
In that drawing, dimensions are in some settings like, ext.line color - red, text color - green,...
But all objects(lines, dimension lines, texts) are displaying in white color only,.
This drawing drawn in old versions (not sure which version)
But properties of the objects are as per settings (please see attached picture)
How to solve this issue,.
Thanks in advance,.
2 REPLIES 2
nestly2
Plotstyles override layer/object properties.   "Display with Plotstyles" (monochrome) is checked in the PAGESETUP dialog box.
PAGESETUP > Modify > Display with Plot Styles
in reply to: nestly2
Thank U very much,.
Problem solved by your solution,....
”Boost
