AutoCAD Forum
Object Properties in the toolbar...
3 REPLIES 3
355 Views, 3 Replies
Ok, from the beginning of time I have been able to pick on a line/object/block/etc., and the properties manager in the toolbar at the top of the screen would show that object's properties and I could change the properties of that object.
For some reason when I installed the program on a new computer, that no longer works.  The properties of the entitiy I select do not show on the toolbar.
I cannot for the life of me find the command option to allow me to fix this.
Anyone please help!!
3 REPLIES 3
rkmcswain
Set PICKFIRST = 1
drjohn
Actually, if the PROPERTIES panel is completey blank there may a registry key missing.
Use a reg cleaner recently? Remove other ADESK products?
Anyway, if you the cure for that is to do a REPAIR install thru the Win control panel ADD/REMOVE and all will be well again.
You may need the disk, serial and activation code for this.
HTH
DJ
dgorsman
in reply to: drjohn
Unchecking the 360 module in the installer (as opposed to manually changing the deployment) can also produce this effect.
”Boost
