AutoCAD 2010/2011/2012
Distinguished Contributor
kwg06516
Message 1 of 2 (172 Views)
not understanding constraints in blocks
172 Views, 1 Replies
01-09-2013 11:36 AM
I'm trying to create a very simple dynamic block for a elevation of a countersunk hole.
There are four inputs that matter:
D1. countersink diameter
D2. hole or drill diameter
D3. depth of material
R. rotate the whole block
The problem is the throat line.  I've been tinkering around with geometric constraints trying to get it to move the throat line by its endpoints which are the intersections of the countersink and drill wall lines.  The linear movement of D1 & D2 generates 2D movement of these endpoints.  Angle constraints keep the angles of the walls correct but when I constrain the endpoints the movement of either D1 or D2 produces unexpected chained movements of the other lines.  D1 (countersink) should not move the drill wall line but it does.  That should stay where it is while only its endpoint at the countersink moves up and down.  Maybe I just don't understand the math of what drives what and I selected or contrained elements in the wrong order.  Or am I trying to do something that AutoCAD is incapable of doing?
I've attached a sketch of what I'm trying to accomplish and the failed block.
AutoCAD 2010
AutoCAD LT 2013
Revit Architecture LT 2013
Active Contributor
LaserGuy
Message 2 of 2 (137 Views)
Re: not understanding constraints in blocks
01-10-2013 06:24 AM in reply to: kwg06516
Not a block, but see attached
Dell T7500
x5690 Xeon 3.46/3.73GHz
48Gb, 12 SSDs, Quadro 2000,
K40 Tesla, Win7 x64
AutoCAD Mechanical 2015
Ansys Mechanical 15
Announcements
Need installation help?
