AutoCAD 2010/2011/2012
Active Contributor
1 Kudo
Post 1 of 11
Not Able to get the Legs as they should be
276 Views, 10 Replies
08-10-2011 05:28 PM
I am not able to get the legs the way thye are supposed to be per AutoCad's "Create Basic 3D Objects" tutorial. The image on the left is from AutoCad's Tutorial, lesson 1,                                          steps 7 through 11, and the image below the left one is what I drew in AutoCad 2011, 3D Modeling per Lesson 1 (steps 7 - 11) of the tutorial. As you can see the left one has the top narrower than the bottom, whereas, the right one has the top wider than the bottom.
601 Kudos
Post 2 of 11
Re: Not Able to get the Legs as they should be
08-10-2011 09:06 PM in reply to: TonyDe
It said in the tutorial you have to set  OBJECT SNAP to on, if you don't use this option, then you have to specify the diameter (or radius) for the top of the leg before drawing bottom diameter (or radius) and height.
Active Contributor
1 Kudo
Post 3 of 11
08-11-2011 11:12 AM in reply to: Patchy
for Patchy,
I did have OBSnap se tto on.
601 Kudos
Post 4 of 11
08-11-2011 11:18 AM in reply to: TonyDe
But the important setting you did not do is OSNAP.
command: OSNAP, select all (Put check marks on all of them)
Active Contributor
1 Kudo
Post 5 of 11
08-11-2011 12:21 PM in reply to: Patchy
For Patchy,
Below is the exact wording of Steps 7 &  8of lesson 2 of Create Basic 3D Objects.
1). 7 At the prompt, move the cursor over one of the smaller circles. The center point of the circle is displayed. Click the center of the circle in the drawing.
What I assumed by step 7 was to move the cursor over one of the smaller circle>click center of the circle in the drawing. I assumed the center of the larger circle was what it was referring to.
2). 8 At the prompt, enter T for top radius and press Enter.
Specify center point of base or (3P/2P/Ttr/Elliptical): t
Specify point on object for first tangent: (AutoCad 2011)
What point or object is it referring to??? Note: could not go any farther.
601 Kudos
Post 6 of 11
08-11-2011 12:29 PM in reply to: TonyDe
 The author assumed that a user already know how to select center of the top circle and also know how to click on the circumference before proceding with drawing the rest of the leg (Telling a user how to do every tiny steps is kind of insulting)
3d is advance drawing part of autocad.
You can yell at whoever wrote it if you want.
*Pro
169 Kudos
Post 7 of 11
08-11-2011 12:48 PM in reply to: Patchy
The directions are incomplete/ incorrect, there needs to be one more step between 7 & 8. The default settings for a cone draws a cone the converges all the way to a single point. The instructions fail to mention that in order to achieve the desired result, the user has to specify both a "base" and a "top" radius.
601 Kudos
Post 8 of 11
08-11-2011 01:03 PM in reply to: nestly
I believe the author wants you to use Osnap (it's was the first thing in the tutorial)
He or she skipped the line that said click on the small top circle after picked center point.
Like I said, yell at him/her
*Pro
169 Kudos
Post 9 of 11
08-11-2011 01:10 PM in reply to: Patchy
Also, the image in Step 4 clearly shows that Dynamic Input is turned on, so entering a height of -4 would be result in the table leg being drawn upward through the table top if the user picked a point "below" the center of the small circle to specify the top radius, or if the user happened to move their mouse "down" anytime after step #7
The first time I tried it, I did assume that I was supposed to snap to the circumference of the circle, however I picked the quadrant of the smaller circle that's SE of the center, so of course the leg went "up" with a height of -4
601 Kudos
Post 10 of 11
08-11-2011 01:15 PM in reply to: nestly
Yup, it is a bad example of 3d for Tony (He's a beginner)
