Node snaps for blocks have mysteriously stoped working. They are working for mtext corner and points. Audit, purge, close & reopen don't resolve the issue.
Is there a setting for this?
Solved by jggerth. Go to Solution.
This might be it...
From the Help file,
"When the system variable WHIPARC is set to 1, you might find that AutoCAD®
fails to locate object snap points on block insertions. The problem is often
noticed when you cycle through object snaps in a block by pressing the TAB
key."
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
i don't recall block instances ever having a NODe Osnap, unless a POINT object was part of the block definition. INSertion yes, along with the other geometric OSnaps...
