AutoCAD 2010/2011/2012
Active Contributor
bluebull
Message 1 of 7 (789 Views)
New Semi-Ortho
789 Views, 6 Replies
01-20-2013 09:04 PM
The F8 key has been used for years to turn ORTHO on or off. The option to pick ORTHO on the status line below the drawing area has always been available as, since AutoCAD 2006, holding down on the SHIFT key will give you instance ORTHO.
However on my laptop I have AutoCAD 2010,  and this feature does not work. On the other PC AutoCAD 2009 installed, and works fine. Is there a setting to be ajusted or something else that I havo no idea.  Anybody have an anwser or a clarification...
Thank You Alex B.
bluebull,
see the System Variable
TEMPOVERRIDES, should be 1
Hope that helps
Henrique
Alfred.NESWADBA
Message 2 of 7 (776 Views)
Re: New Semi-Ortho
01-20-2013 11:41 PM in reply to: bluebull
for me it works with 2010 too. And I would not know a sysvar that does influence it working or not.
Have you installed the latest servicepack for AutoCAD?
Does that happen only in one drawing or also in new ones?
What happens if you login to your workstation with anohter user-account and try it again (so the AutoCAD profile is as clean as possible).
- alfred -
Alfred NESWADBA
hmsilva
Message 3 of 7 (760 Views)
Re: New Semi-Ortho
01-21-2013 01:27 AM in reply to: bluebull
bluebull,
Hope that helps
Henrique
Alfred.NESWADBA
Message 4 of 7 (756 Views)
Re: New Semi-Ortho
01-21-2013 01:46 AM in reply to: hmsilva
@hmsilva:
- alfred -
Alfred NESWADBA
hmsilva
Message 5 of 7 (751 Views)
Re: New Semi-Ortho
01-21-2013 01:52 AM in reply to: Alfred.NESWADBA
Thank you, Alfred
Cheers
Henrique
Active Contributor
bluebull
Message 6 of 7 (716 Views)
Re: New Semi-Roth
01-21-2013 08:23 PM in reply to: hmsilva
TEMPOVERRIDES,  should be 1......this is exactly what makes sense to resolve my small deception with Semi- Ortho,
I  appreciate your prompt relay on the matter.
Thank you, AB
hmsilva
Message 7 of 7 (706 Views)
Re: New Semi-Roth
01-22-2013 01:02 AM in reply to: bluebull
Glad I could help
Henrique
