I am using Autocad 2011 and want to write a macro fo it but I went to open the vba editor and it said that it is nolonger woth Autocad. I went to the site to find it and the earliest version I saw was VBA 2013, will this work with Autocad 2011?
Solved by jabman81. Go to Solution.
Good you solved it. It would be kind if you could briefly tell the solution as it will be of good help to many people.
