AutoCAD 2010/2011/2012
*andrew.nao
Message 1 of 8 (577 Views)
need some structural steel size info
577 Views, 7 Replies
05-10-2010 10:16 AM
hello all,
If anyone could help me out I would appreciate it.
Im working on project that involvles structural tee
WT3 X 6 to be exact.
when labeling the this item, out customer requested we also list the metric
equivalent of the piece also.
my company doesn't normally deal with structural steel like this
so if anyone could help me and provide me with maybe some type of conversion
sheet or any info that would show me the equivalent of this steel piece in
english and metric I would very much appreciate it
thanks
*Expert Elite*
Patchy
Message 2 of 8 (577 Views)
Re: need some structural steel size info
05-10-2010 10:40 AM in reply to: *andrew.nao
1/2 of W6x12
http://www.aisc.org/DynamicTaxonomyFAQs.aspx?id=1504
*Bill Gilliss
Message 3 of 8 (577 Views)
05-10-2010 10:42 AM in reply to: *andrew.nao
On 5/10/2010 1:16 PM, andrew.nao wrote:
> hello all,
> thanks
Do you need the dimensions of the metric tee that is closest to this
one, or the metric dimensions of the WT 3x6?
I do not see a close match at
http://metricmetal.com/products/metrictee.htm, but there are other
sources, especially if it is cut from a W shape as the WT 3x6 is.
A-36 steel? A-57? Be careful.
I have worked on auto parts plants in the US (none recently, alas),
where very specific metric wide flange shapes were specified by the
Japanese equipment manufacturers for support structures. Determining
imperial equivalents that were structurally equivalent and also provided
required clearances usually took numerous conversations with Japan.
*jg
Message 4 of 8 (577 Views)
05-10-2010 11:04 AM in reply to: *andrew.nao
A WT3X6 IS 3.015" DEEP WITH A 4" FLANGE.
Stem is 0.230" thick and flange is 0.280" thick. To convert to mm
multiply inch dimensions by 25.4
> hello all,
> thanks
*None
Message 5 of 8 (577 Views)
05-10-2010 02:38 PM in reply to: *andrew.nao
On 5/10/2010 12:16 PM, andrew.nao wrote:
> hello all,
> thanks
Metric steel comes in different sizes than AISC sizes. I have a program
to draw AISC members and *some* metric members (W,R,C and A shapes) but
no WT shapes. However, WT shapes are cut from W shapes so I would think
that a metric W shape of 150UB14 would be proper. See attached:
*andrew.nao
Message 6 of 8 (577 Views)
05-11-2010 06:11 AM in reply to: *andrew.nao
None,
the call out of the size 150ub14 is what im looking for
its appreciated
would you happen to have a list of all the sizes or was this something you
pulled off your program?
would you know where I could find a list?
ive been googling for 2 days and im not able to find any type of list that
shows the english to metric conversions
*andrew.nao
Message 7 of 8 (577 Views)
thank you everyone for your help
New Member
meganke
Message 8 of 8 (244 Views)
10-30-2012 04:48 PM in reply to: *andrew.nao
Thank for your question. For structural steel building there are various sources that can help you. It will all be depend on what you are trying to accomplish. Try them first www.bungersteel.com I heard they are the best on the business. Hope that helps. Good luck with everything.
Announcements
Need installation help?
