AutoCAD 2010/2011/2012
Valued Contributor
tstorzuk
Message 1 of 3 (440 Views)
Navigation Cube isn't visible on screen
440 Views, 2 Replies
08-31-2011 07:16 AM
Need a little help here. On one of our computers, the navigation cube isn't visible. We've tried;
CUBE = ON
NAVVCUBE = ON
NAVVCUBEDISPLAY = 1
CUBE - settings - all different positions to display on screen
What other options/switches should we try?
azrdgldr
Message 2 of 3 (426 Views)
Re: Navigation Cube isn't visible on screen
08-31-2011 10:34 AM in reply to: tstorzuk
Use the sysvdlg command at the command prompt and scroll down and find the variables that control the cube settings and adjust accordingly.  When you pick a variable there it gives the options to decide what to set it to.
*Pro
nestly
Message 3 of 3 (414 Views)
08-31-2011 01:52 PM in reply to: tstorzuk
NAVVCUBEDISPLAY = 1 only displays the Viewcube when you're in a 3D Visual style  (ie not 2D wireframe)
Try NAVVCUBEDISPLAY = 3 to always have the Navvcube displayed.
Also remember that each viewport has it's own viewcube display setings, so if NAVVCUBEDISPLAY was 1 when you created the viewport(s), you'll have to change it for each viewport.
