AutoCAD Forum
Multiple views, diff sizes
3 REPLIES 3
doni49
239 Views, 3 Replies
@AllenJessup,
I just came across your post in an old thread.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Multiple-Windows-of-the-same-drawings/m-p/489...
You showed the following screen shot.  Are you working on a layout tab or in Modelspace?  If Modelspace, how'd you resize your views like that?
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
3 REPLIES 3
AllenJessup
in reply to: doni49
Modelspace. It's a process. A little difficult to explain. The main trick is the use of:
Command: -VPORTS
Enter an option [Save/Restore/Delete/Join/SIngle/?/2/3/4/Toggle/MOde] <3>:
I create multiple viewports by breaking apart larger ones. I usually do this by setting the Apply to: field in the Viewports dialog box to Current Viewport
Then when I have it about right I use the Join option on the command line (shown above). In the example. The upper right viewport on the left hand screen would have been created by joining (probably) 4 viewports. Maybe 3 - I don't quite remember. I then save the viewport configuration so if I lose it I can reset it without all the work.
Allen
Allen Jessup
CAD Manager - Designer
doni49
in reply to: AllenJessup
Thanks!  That's going to open up lots of possibilities for me!  I've known about breaking one view into smaller ones but I've never noticed the JOIN option.
NICE!
Don Ireland
AllenJessup
in reply to: doni49
As you see. They never migrated it from the command line to the dialog box. I was just familiar with the command line.
Allen
Allen Jessup
”Boost
