AutoCAD 2010/2011/2012
Active Member
danjvaldez
Message 1 of 5 (886 Views)
Multi Leader Settings
886 Views, 4 Replies
06-22-2011 01:11 PM
Is there any way to specifiy from which point a multi-leader should originate from? As it is right now, I can only draw a multi-leader where each leader originates from the text. Below is a picture of what I'd like to do:MLEADER.jpg
pendean
Message 2 of 5 (878 Views)
Re: Multi Leader Settings
06-22-2011 06:18 PM in reply to: danjvaldez
MLEADERSTYLE command, explore it, tap HELP if you get stuck
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Mentor
TrevN
Message 3 of 5 (869 Views)
06-23-2011 02:32 AM in reply to: pendean
Change the landing distance, this should give you what you want.
Active Member
danjvaldez
Message 4 of 5 (859 Views)
06-23-2011 09:00 AM in reply to: danjvaldez
Changing the landing distance only works with straight leaders. I was hoping for a solution to work with spline leaders. This is for mapping documents where curved leaders are used to differentiate information call-outs from straight line work. Any ideas?
Thanks for taking the time to answer!
Valued Mentor
TrevN
Message 5 of 5 (857 Views)
06-23-2011 09:14 AM in reply to: danjvaldez
The only work around I can think of at the mo is to increase the landing gap, then manually draw in another spline.
I kow it's not great, but until AC make a change to this that's all I can think of, unless some clever bod out there can come up with some swanky lisp routine?!!
(You could add this to the wish list?)
