AutoCAD 2010/2011/2012
0 Kudos
Post 1 of 6
MTEXT With Problems
1389 Views, 5 Replies
04-04-2011 06:17 AM
Hi everyone
I have an issue with the MTEXT. When I try to edit what is written inside the windows of the MTEXT, the text rotates and goes to the vertical position. Even If i change the Rotation angle to 0 on properties, when i finish editing the text it rotates again to the vertical position.
The issue is on the video.
There is something wrong with the style used. I was able to copy/paste into a new mtext box without formatting.. i used the "Standard" style, and i was able to edit it. This is a very strange bug.
For some reason the font "arial unicode ms" is buggy with ACAD...in your dwg, whenever I changed the font in the same style, everything came out fine.
Hi !!
I found out what was happening.
every font with the @ at the begining like "@arial black"  is made to right in the vertical position.
to solve the problem you have to choose the same font, but without the @.
Distinguished Contributor
2 Kudos
Post 2 of 6
Re: MTEXT With Problems
04-04-2011 07:24 AM in reply to: EduardoBoarati
0 Kudos
Post 3 of 6
04-04-2011 07:39 AM in reply to: EduardoBoarati
0 Kudos
Post 4 of 6
04-04-2011 11:02 AM in reply to: JACERAC
thanks guys for your help,
If i discover that its really a bug with the arial unicode ms i'll post it here later.
Thanks again.
0 Kudos
Post 5 of 6
04-08-2011 10:26 AM in reply to: EduardoBoarati
Hi !!
Active Contributor
0 Kudos
Post 6 of 6
01-22-2013 01:04 PM in reply to: EduardoBoarati
ABSOLUTELY CORRECT ARIAL FROM MICROSOFT  IS BUGGED,,,, USELESS, WHY THEY THIS ??  GO FIGURE.
