AutoCAD 2010/2011/2012
Distinguished Contributor
fxcastil
Message 1 of 10 (668 Views)
Mouse is "jumpy" or setting mouse resolution
668 Views, 9 Replies
12-17-2012 08:38 AM
When I open a large facility building drawing my mouse is "jumping" on the screen.
The resolution of the mouse does not allow me to select obejects on the screen because the mouse jumps in large increments.
I do not have this problem on smaller drawing, such as electrical schematics.
Is there a setting to increase the resolution of the mouse movemrnt id AutoCAD?
Alfred.NESWADBA
Message 2 of 10 (667 Views)
Re: Mouse is "jumpy" or setting mouse resolution
12-17-2012 08:44 AM in reply to: fxcastil
ROLLOVERTIPS ==> set it to 0
SELECTIONPREVIEW ==> set it to 0
HTH, - alfred -
Alfred NESWADBA
troma
Message 3 of 10 (659 Views)
12-17-2012 09:25 AM in reply to: fxcastil
Is SNAP on (F9) ?
(I don't mean OSNAP)
Credit where credit is due! Give kudos or accept as solution whenever you can.
*Pro
murray-clack
Message 4 of 10 (649 Views)
12-17-2012 09:39 AM in reply to: troma
The biggest culprit I've come across is using the Layer Palette instead of the "old fashioned" dialog box.
You can either use the command CLASSICLAYER, or set the sysvar LAYERDLGMODE to a value of 0
fxcastil
Message 5 of 10 (628 Views)
12-17-2012 11:39 AM in reply to: fxcastil
The "snap" is not on.
Thanks for all the suggestions, I tried all the above suggestion (variable setting) but I still have the same problem.
If I zoom out on the drawing I do notice the "jumpy" mouse problem.
But if I zoom in on this large facility drawing I have the "jumpy" mouse problem.
I sometimes see a blue faded box close to the mouse pointer.
More suggestions would be most appreciated.
*Pro
murray-clack
Message 6 of 10 (625 Views)
12-17-2012 11:42 AM in reply to: fxcastil
The blue box sounds like the Selection Cycling is turned on.  Enter the sysvar SELECTIONCYCLING  and set it to 0
fxcastil
Message 7 of 10 (591 Views)
12-18-2012 07:21 PM in reply to: fxcastil
Thanks Murray, the "SELECTIONCYCLING" Variable fixed my jumpy mouse, you have earned your Distinguished Mentor Status.
With so variables to set, I now need  to find a complete variable list for 2011 AutoCAD.
Alfred.NESWADBA
Message 8 of 10 (582 Views)
12-18-2012 11:33 PM in reply to: fxcastil
You can find it >>>here<<< or, if you have installed ExpressTools then start command SYSVDLG.
- alfred -
Alfred NESWADBA
*Pro
murray-clack
Message 9 of 10 (571 Views)
12-19-2012 07:04 AM in reply to: fxcastil
Cool!  Glad I could help
SugarCAD
Message 10 of 10 (507 Views)
12-27-2012 12:29 PM in reply to: fxcastil
You should setup your acaddoc.lsp to set your System Variables as you like them on startup.
