AutoCAD Forum
missing tool bars in classic workspace
6 REPLIES 6
u2assaf
793 Views, 6 Replies
I Have recently installed the autocad2012 and managed to add the classic workspace .
but there are manny toolbars that are missing  like the dimension tool bar.
can you please guide me how to add it?
Tags (1)
6 REPLIES 6
u2assaf
in reply to: u2assaf
I have only a limited amount of tool bars option as you can see in the attached file
Tags (1)
Patchy
How did you add classic workspace? It would be easier to go to Options, Profiles, and double click on AUTOCAD. Everything already there for you to use as classic.
u2assaf
in reply to: Patchy
I did as you suggested but it changed it to ribbon as you can see in attached file (toolbars2) and I want classic workspace with all the toolbars available but for some resone they are very limited as you can see in the previos attached file.
u2assaf
I moved back to classic workspace and now all the toolbars are available so it looks like the problem is solved.
Thank you verry much
Smiley Wink
u2assaf
in reply to: Patchy
Thank you for your help
but now I need to do this procedure after every time I shutdown the software is there a way to keep the setup?
so it will turn on the classic workspace with all the toolbars available.
Patchy
After setting up the workspace you like, remember to Save your workspace, use a different name for ez remembering.
Which version of windows are you using? if it's 8, that could cause problem of compatability.
”Boost
