AutoCAD 2010/2011/2012
Active Member
RUTHMASON
Message 1 of 12 (9,629 Views)
missing acad.msi folder
9629 Views, 11 Replies
07-04-2011 01:21 PM
HI gang
I'm not a techy... I'm an interior designer (enough said)... but my 2010 has failed a few times recently during routine 3-d drawings.  I was sent a link to an update from autodesk, but when I try to install I get an error message saying that the feature I am trying to use is on a network resource that is unavailable.  The source is looking for C:\GerdooTemp\x86\acad\ plus it says it's looking for an "acad.msi" folder.
Anyone??
Thanks so much
Ruth
Product Support
luconceicao
Message 2 of 12 (9,578 Views)
Re: missing acad.msi folder
07-06-2011 06:24 AM in reply to: RUTHMASON
You could try inserting the installation disk ofAutoCAD 2010 on the drive and, when the message appears, point to the acad.msi file in the disc (Drive:\x86\acad\acad.msi).
Hope this helps,
Luciane
Active Member
RUTHMASON
Message 3 of 12 (9,566 Views)
07-06-2011 11:24 AM in reply to: luconceicao
Thanks for the note. But I purchased my software from you guys online and downloaded it.  So I never got a disk.  What do I do without a physical disc?
Ruth
Product Support
luconceicao
Message 4 of 12 (9,553 Views)
07-07-2011 06:13 AM in reply to: RUTHMASON
Hi Ruth,
Without a disk is the same thing.
If you have downloaded the installation files, the acad.msi will be in the same folder as indicated earlier.
When prompted, browse to the folder where acad.msi is located and it should work.
According to your initial post, the installation files were in C:\GerdooTemp but they cannot be found now (you probably moved or deleted the folder).
Hope this helps,
Luciane
Active Member
RUTHMASON
Message 5 of 12 (9,524 Views)
07-13-2011 10:59 AM in reply to: luconceicao
Hi Luciane
I can't think of why I would delete this but it is not anywhere on my computer.  So what do I do?  How can I reload the software without a disk so I can get the file back?  Otherwise I have a very expensive but useless piece of software sitting on my computer and I'm getting very frustrated.
Thanks so much
Ruth
Product Support
luconceicao
Message 6 of 12 (9,517 Views)
07-14-2011 06:02 AM in reply to: RUTHMASON
Hi Ruth,
If you downloaded it from the Subscription Center then you can download it again:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=613372
If not (or if you are not sure, or if you can't remember your login details) then please contact our Business Center.
If you tell me where you are then I can send you the contact details.
Cheers,
Luciane
Active Member
RUTHMASON
Message 7 of 12 (9,513 Views)
07-14-2011 01:57 PM in reply to: luconceicao
Thanks Luciene
Mason Design Group Ltd
in West Vancouver, BC Canada
Ste 1 - 650 Clyde Avenue
I'll try this link anyway.  Not sure what it will ask of me... but I'll look forward to getting your info regardless.
Thanks for your help!
Cheers
Ruth
Product Support
luconceicao
Message 8 of 12 (9,499 Views)
07-15-2011 06:00 AM in reply to: RUTHMASON
Hi Ruth,
Please use this form:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12338355
Cheers,
Luciane
Product Support
luconceicao
Message 9 of 12 (9,496 Views)
07-15-2011 06:05 AM in reply to: luconceicao
If the link above does not work, go to Autodesk.com, on the top click Contact Us, then click Web Form on the top right.
For some reason the link did not work for me when I clicked it to test.
Active Member
RUTHMASON
Message 10 of 12 (9,477 Views)
07-18-2011 03:02 PM in reply to: luconceicao
Hi Luciene
Sorry to be a pest but I still have not heard back from the form I sent to the "contact us" guys last Thursday.  I received a computer generated conformation that my form got to them but still no update on how I can reload my soft ware.  I even sent them the serial number for the software.
Any other thoughts?
Ruth
Announcements
Need installation help?
