AutoCAD 2010/2011/2012
Active Member
jbdickson
Message 1 of 8 (326 Views)
migrating from AutoCAD 2010 to 2011
326 Views, 7 Replies
11-30-2012 05:25 PM
In Windows Explorer I have clicked on Start>Programs>Autodesk>AutoCAD 2011>Migrate settings from a previous release.  The message "You must have AutoCAD 2000 or later loaded on computer to migrate settings" appears.  No further options given although AutoCAD2011 is loaded on the computer.
What is the problem?
*Expert Elite*
Alfred.NESWADBA
Message 2 of 8 (313 Views)
Re: migrating from AutoCAD 2010 to 2011
12-01-2012 12:19 AM in reply to: jbdickson
what product exactly do you have (plain AutoCAD 2011 or a vertical product like ACA, MEP, Mech, Map3D, Civil3D, ...)?
And what previous product (exactliy) is installed on tthis computer too? And does this product also start without any issue?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
pendean
Message 3 of 8 (309 Views)
Re: migrating settings into AutoCAD 2011
12-01-2012 04:36 AM in reply to: jbdickson
Do you have a previous release of AutoCAD installed?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
jbdickson
Message 4 of 8 (296 Views)
12-01-2012 05:57 PM in reply to: Alfred.NESWADBA
Thanks for your interest. I have a new computer, running Windows 7 Professional, and have just installed AutoCAD 2011 (the basic program; but full AutoCAD, not LT). The program is running satisfactorily in its raw, uncustomized state. My somewhat older computer (Windows 7 Home Premium) has my customized AutoCAD 2010 running on it. My customized settings have been exported to a zip file (AutoCAD 2010_cust_settings.zip) using Windows Explorer. I was hoping to import/migrate into 2011 also using Windows Explorer but when clicking on Autodesk>AutoCAD 2011>Migrate Settings from a previous release the message “Migrate Profiles requires that AutoCAD 2000 or a later version be installed on your system”. I don’t understand why my computer is not recognising the presence of AutoCAD 2011. Thanks again
*Expert Elite*
Alfred.NESWADBA
Message 5 of 8 (295 Views)
12-01-2012 08:26 PM in reply to: pendean
Ok, that's the point. The migration utility does only handle customization data from an AutoCAD-installation on the same computer as 2011 installed.
So if it does not find an older AutoCAD it stops with no action.
- alfred -
Alfred NESWADBA
Active Member
jbdickson
Message 6 of 8 (293 Views)
12-01-2012 11:26 PM in reply to: Alfred.NESWADBA
Many thanks. May I ask you what you think is the most straightforward way of migrating the settings - from 2010 on one computer to 2011 on another.
*Expert Elite*
Alfred.NESWADBA
Message 7 of 8 (291 Views)
12-02-2012 01:43 AM in reply to: jbdickson
Ask the one who did customizations, then you know:
  • what files are modified or added (menu, pgp, lsp/vlx, dvb, dll, arx, ...)
  • what tools or applications are loaded (they have to be installed separately)
  • what profile-settings where changed from default
And install/add/modify them in the same way to your new AutoCAD-profile. It is not the fastest way to do that, but it's the most clean way (also to get rid of some historical not any more used things).
A tip for the next time, if you do menu.modifications: do them in a separate CUIX-file, then you have the chance to load this menu as partial menu and that's it.
And an additional info: I never would use the migration that AutoCAD has built in, even when I have the older release installed and running!
- alfred -
Alfred NESWADBA
*Expert Elite*
pendean
Message 8 of 8 (266 Views)
12-03-2012 05:53 AM in reply to: pendean
What are the contents of this ZIP file?
What program bundled the ZIP file for you? Or did you do it manually?
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
