AutoCAD 2010/2011/2012
New Member
muhammedriyas
Message 1 of 4 (591 Views)
mbuttonpan
591 Views, 3 Replies
02-04-2013 07:53 AM
dear sir,
when i open one drawing i want to change mbuttonpan value is 1. how can change the value 1 ever? and polyline thickness also i want to change in option. please send the solution.
Patchy
Message 2 of 4 (586 Views)
Re: mbuttonpan
02-04-2013 08:10 AM in reply to: muhammedriyas
MBUTTONPAN variable stores in the registry, no reason to change in a drawing.
PLINEWID stores in a drawing, change it in your template drawing.
For any drawing that you open and you need to set default PLINEWID, make it happen by using ACADDOC.LSP
New Member
muhammedriyas
Message 3 of 4 (576 Views)
Re: mbuttonpan & ployline
02-04-2013 08:54 AM in reply to: muhammedriyas
Dear sir,
As my previous mail, I don't get clear answer from you. Please mention how I can solve these problems?
1) I need to change mbuttonpan value 1, when I open every drawing.
2) I need to change polyline width in option, when I open every drawing.
Please give the correct answer for these problems, or attached jpg for this.
Patchy
Message 4 of 4 (542 Views)
02-05-2013 06:30 AM in reply to: muhammedriyas
MBUTTONPAN is a variable you set it once and it doesn't change the next time you open another drawing, if you have to reset it to 1 all day, you need to repair your autocad.
PLINEWID is not a variable you change in OPTIONS, you choose your pline width for default and save your drawing as a template.
Both of those variables can be set by using ACADDOC.LSP (Hit F1 and read about it) and input whatever you want when a new drawing is opened.
For example:
(setvar "mbuttonpan" 1)
(setvar "plinewid" 25)
