AutoCAD 2010/2011/2012
V
Active Member
V
Message 1 of 10 (4,872 Views)
mbuttonpan doesn't work!
4872 Views, 9 Replies
08-23-2010 12:02 PM
When I type "mbuttonpan"  so I can depress my mouse roller ball to pan, it doesn't work.
It worked on a different wireless mouse.
The one I am currently using is a wireless Logitech EX100 mouse.
V.
namssurt
Message 2 of 10 (4,868 Views)
Re: mbuttonpan doesn't work!
08-23-2010 12:22 PM in reply to: V
set the middle button in setpoint to middle button.
jg
V
Active Member
V
Message 3 of 10 (4,861 Views)
08-23-2010 12:37 PM in reply to: namssurt
jg,
UMM... Where is the setpoint?
V.
V
Active Member
V
Message 4 of 10 (4,856 Views)
08-23-2010 12:52 PM in reply to: V
Fixed it!
Thanks!
Active Member
eelkovdm
Message 5 of 10 (4,365 Views)
03-09-2011 02:11 AM in reply to: V
I have a similar problem,
I use a logitech G5 laser mouse, and have my scrolle wheel set to middle button in setpoint.
mbutton pan variable is set to 1 and still I can't pan.
it has worked on this computer but afther upgrading to AutoCAD Civil 3D 2011 is has stoped working.
OS = Windows xp 64bit
any other solutions to this problem out there?
would be mutch appreciated
M_Hensley
Message 6 of 10 (4,360 Views)
03-09-2011 03:36 AM in reply to: eelkovdm
To get my middle button to work properly with AutoCAD I had to go into control panel > mouse > wheel > exceptions and add AutoCAD as an exception.  (Not all mouse drivers have this ability.)
Active Member
eelkovdm
Message 7 of 10 (4,354 Views)
03-09-2011 03:57 AM in reply to: M_Hensley
I'm using setpoint and have added autocad as a "game" and then again set the scroll wheel as middle button.
but no succes yet....arggggg
New Member
caspidopapidos
Message 8 of 10 (4,353 Views)
03-09-2011 03:59 AM in reply to: V
try setting a ne value, it must work interchage between <1> and <0> values
Active Member
steve.grace
Message 9 of 10 (3,642 Views)
04-11-2012 09:33 AM in reply to: caspidopapidos
I have 2 different PC's with Logitech mice... One wireless, one corded. I have found that the Logitech SetPoint mouse software causes a major lag with the scroll wheel pan (with the scroll wheel set to Middle button instead of the default zoom). I have uninstalled the Logitech Setpoint software and the OS (Windows7 64 in my case) defaults the mouse to HID-compliant mouse. Pan and zoom on the scroll wheel work great in AutoCAD and the forward-back buttons still work in IE.
Downside is that you will loose any additional button functionality on the mouse (Application switching, keystroke customization and other goodies)....  Not a problem for me.
New Member
davelowrance
Message 10 of 10 (2,833 Views)
02-09-2013 10:21 PM in reply to: namssurt
This solution previously noted to set wheel as "middle button" in Setpoint worked for me.  It was somehow set as "Mouse:zoomset".  I set this under "Select Program - AutoCAD Application".  MBUTTONPAN set to "1".
