AutoCAD 2010/2011/2012
New Member
st0ne
Message 1 of 4 (1,707 Views)
match font properties...
1707 Views, 3 Replies
11-30-2011 06:51 AM
when i attempt to match the properties of an edited multiline text box; the size and colour change but the ‘font’ doesn’t? anyone else had this problem?
*Expert Elite*
Patchy
Message 2 of 4 (1,702 Views)
Re: match font properties...
11-30-2011 07:10 AM in reply to: st0ne
Everyone does and most have used stripmtext.lsp to remove the font override.
*Expert Elite*
pendean
Message 3 of 4 (1,680 Views)
12-01-2011 04:38 AM in reply to: st0ne
If someone, or you, manually changed the font INSIDE the Mtext Editor box, you cannot change it from outside the Mtext editor without special tools as noted above.
Same issue if anyone changes anything manually inside the Mtext Editor: it's called an override.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
pustulka
Message 4 of 4 (126 Views)
10-20-2014 09:10 AM in reply to: st0ne
Another way- not perfect but quick- is to match the properties and then explode- the font will update. The problem is that it's no longer Mtext then, just a text..
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
