AutoCAD 2010/2011/2012
Valued Contributor
mail
Message 1 of 5 (342 Views)
Macro 8x11 PDF quick button
342 Views, 4 Replies
09-26-2012 11:53 AM
I have the following macro for a quick PDF.  This works the first time you use the button, however, it does not work multiple times.  The new PDF won't override the previous one saved and cancels the command.  I would ideally like for a diaglouge box with a save prompt to appear, but I am unsure of how to do this.  Feedback would be greatly appreciated.  This is a very handy macro.
Thanks!
^C^C-PLOT;Y;;DWG TO PDF.PC3;ANSI A (8.50 X 11.00 INCHES);I;P;N;W;\\;C;Y;CLIENT.CTB;Y;;;;;^C^C
New Member
cchuls
Message 2 of 5 (336 Views)
Re: Macro 8x11 PDF quick button
09-26-2012 01:00 PM in reply to: mail
We used to have the same problem on our older version of AutoCAD, but now we switched over to teh AcroPlot Pro soft ware. It's very user friendly and the PDF files are half the size if you would create it with Adobe Professional.
*Expert Elite*
pendean
Message 3 of 5 (307 Views)
09-27-2012 06:00 AM in reply to: mail
Valued Contributor
mail
Message 4 of 5 (260 Views)
10-03-2012 12:37 PM in reply to: cchuls
Try this macro for AcroPlot.  Change "Client" to the name of your *.ctb file.
^C^C-PLOT;Y;;PDF-XChange for AcroPlot Pro.pc3;Letter/ANSI A;I;P;N;W;\\F;C;Y;CLIENT.CTB;Y;;;;y;
Valued Contributor
mail
Message 5 of 5 (257 Views)
10-03-2012 12:44 PM in reply to: mail
after you run the command, you need to window the area to print.  Then a prompt should appear asking you where to save the PDF file.  Let me know how this works for you, CC
Post to the Community
New Post
Need installation help?
