AutoCAD 2010/2011/2012
Member
bong5109
Message 1 of 7 (520 Views)
Low of system memory and sometimes fatal error please help
520 Views, 6 Replies
02-13-2013 08:57 AM
Hi there i have a big problem in my autocad 2011 the problem is always coming low of system memory and sometimes fatal error in autocad 2011 when opening the file and sometimes its ramdomly coming. my computer set up are intel i7 3.4gh 8gb memory, intel board, 1 tera drive, Nvidia quadro 600 1gb display adapater. i dont know what is the problem my graphics card is  recommended in the autodesk website. so i dont know what to do right now. anyone can help me please.. i tried even in autocad architecture 2013 but the same problem always coming.. help me..
*Expert Elite*
Alfred.NESWADBA
Message 2 of 7 (519 Views)
Re: Low of system memory and sometimes fatal error please help
02-13-2013 09:03 AM in reply to: bong5109
just to make sure: what operating system do you have (especially 32bit or 64bit)?
And what objects do you have in your drawing? Are there large images or large DWGs referenced or complex 3D-solids? So how big are the drawings you have and what type of drawings are these?
One additional question: what does your task-manager tell you, how much memory is used by the ACAD.EXE when this message pops up?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
braudpat
Message 3 of 7 (479 Views)
02-14-2013 06:45 AM in reply to: Alfred.NESWADBA
Hello
If you are running a Windows 64 bits with 8 Gb Ram on your PC and an AutoCAD 64 bits,
the size (in memory) of your "ACAD.exe" can increase up to about 7 Gb ...
So please check it with the task manager !?
Bye, Patrice
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
Member
bong5109
Message 4 of 7 (462 Views)
02-14-2013 12:43 PM in reply to: Alfred.NESWADBA
Hi there thanks for reply. Im using windows 7pro 32bit. Yes it a big dwg file and full of solid 3d and modified materials.
*Expert Elite*
Alfred.NESWADBA
Message 5 of 7 (459 Views)
02-14-2013 12:54 PM in reply to: bong5109
Sorry, you have more than 4GB built in that can't be used (as it's not addressable with 32bit os), change to Win7 64bit, otherwise only (about) 3GB is usable from OS and only 2GB is usable then from AutoCAD.
- alfred -
Alfred NESWADBA
*Expert Elite*
braudpat
Message 6 of 7 (449 Views)
02-14-2013 11:20 PM in reply to: Alfred.NESWADBA
Hello
Aie, Aie, you MUST use Win Seven 64 bits (not WIn 8) !
The task "ACAD.exe" 32 bits can't use more than about 1.3 Gb memory on ANY 32 bits Windows !!
It's a historical limit of the 32 bits "ACAD.exe" 200x-201x ...
Bye, Patrice
Member
bong5109
Message 7 of 7 (446 Views)
02-14-2013 11:43 PM in reply to: Alfred.NESWADBA
ahh. Ok i will try it now. Its also connected to some fatal error in autocad and sometimes just coming auto cad alert then the application will close. Its that all about in changing to win 7 64bit? anyway thanks a lot after i did i will give u reply. Tnx.
Post to the Community
New Post
Need installation help?
