AutoCAD 2010/2011/2012
Active Member
nsims
Message 1 of 7 (163 Views)
Loss of line color
163 Views, 6 Replies
03-06-2014 01:01 PM
I have one drawing that is loosing the line color when the drawing is opened. I start up AutoCAD and it shows the lines the correct colors. Then as the drawing is still opening it regenerates automatically and before I can put in a command the lines have changed to a grey color. When I try to print the drawing the lines are barely there. Any suggestions?
doni49
Message 2 of 7 (123 Views)
Re: Loss of line color
03-10-2014 07:39 AM in reply to: nsims
Can you post a couple screenshots of this behavior?  Preferrably one showing the lines the right way (you said they look right when you first open the file) and then another when they're NOT right.
Also -- is this only happening on one file?
EDIT:  Does this happen on other computers?  If another user logs in on this same computer, does this happen to them as well?
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Cusomization
Alfred.NESWADBA
Message 3 of 7 (112 Views)
03-10-2014 08:04 AM in reply to: nsims
start command _PAGESETUP (==> modify the current layout), and take a look to the plot style table (upper right corner in the dialog).
There it might be a monochrome or similar CTB or STB assigned ... and ... the checkbox "display plot styles" might be active.
- alfred -
Alfred NESWADBA
Active Member
nsims
Message 4 of 7 (108 Views)
03-10-2014 01:30 PM in reply to: doni49
I found out the drawing was created from another drawing instead of from my template. I have transfered all the data to my template and it is working fine. I would still like to slove this because the person used this same drawing for a couple different projects. The problem happens no matter if we use different computers or log in as different users on a computer. At first you could shut the computer down to restart and the drawing would be correct about every 3rd attempt. I will attach a drawing as it should be and another as has been appearing. Thanks for the help.
Alfred.NESWADBA
Message 5 of 7 (107 Views)
03-10-2014 01:32 PM in reply to: nsims
Waiting then for attachment :smileywink:
- alfred -
Alfred NESWADBA
Active Member
nsims
Message 6 of 7 (102 Views)
03-10-2014 01:50 PM in reply to: Alfred.NESWADBA
Sorry I am still learning this site. I thought I attached it but something happened.
Alfred.NESWADBA
Message 7 of 7 (93 Views)
03-10-2014 03:00 PM in reply to: nsims
how big is your dwg file? Here's a limit of 5MB, if your file is bigger than that then do a upload at any free servers like dropbox or so.
You might also try to first zip the drawing file and upload then the ZIP file.
- alfred -
Alfred NESWADBA
