AutoCAD 2010/2011/2012
Active Contributor
howdylee903
Message 1 of 7 (980 Views)
Lock hatch origin
980 Views, 6 Replies
08-10-2011 11:53 AM
I have a hatch pattern with a non-standard origin point (specified point). I'm try to add one small area to the pattern, but every time I add it, the pattern shifts.
How do I lock the pattern in place? I've tried selecting "store as default origin" but that doesn't help.
Message 2 of 7 (968 Views)
Re: Lock hatch origin
08-10-2011 02:42 PM in reply to: howdylee903
How did you add new area to hatch?  I can do that with either grip edit or add/subtract boundaries from the hatch contextual ribbon and the origin never moves.
Active Contributor
howdylee903
Message 3 of 7 (957 Views)
08-11-2011 04:37 AM in reply to: ToanDN
the 'pick points' button. i can't shift the outline of the hatch because it's going from a straight line into a little bump-out area (not enough grab points to shift). i don't want to create a new hatch because the origin would be different than the existing hatch i'm trying to expand.
Message 4 of 7 (945 Views)
08-11-2011 09:40 AM in reply to: howdylee903
I can add new area to existing hatch by Pick point (from the ribbon tab) and the custom origin point never moves.
pendean
Message 5 of 7 (930 Views)
08-12-2011 05:49 AM in reply to: howdylee903
Active Contributor
howdylee903
Message 6 of 7 (919 Views)
08-12-2011 09:18 AM in reply to: pendean
thanks, but it doesn't help if the origin point is not standard... and it doesn't lock an existing pattern...
*Pro
nestly
Message 7 of 7 (913 Views)
08-12-2011 11:04 AM in reply to: howdylee903
When using the Hatch edit dialog box, the default is "Specified origin".  You have to change it to "Use current origin" or the edited hatch will jump back to the default origin.
It seems the Ribbon default is already "Use current origin"
