My problem with posting on this forum is solved. I just should use Google Chrome, where I can get the "Options" shown, instead of Mozilla Firefox.
So, my lisps from the first post are:
DEFUN C:HH2 () (princ "\n Select Hatch Patterns which Scale will be equal 1") (COMMAND "_-HATCHEDIT" "Properties" " " "1" ; SCALE "" ; ANGLE ) ) and (DEFUN C:HJJ () (princ "\n Select Hatch Patterns which Angle will be equal 0") (COMMAND "_-HATCHEDIT" "Properties" " " " " ; SCALE "0" ; ANGLE ) )
And now I solved this problem in this way:
(DEFUN C:HSCC2 () (princ "\nSelect HatchPatterns to change their HatchScale to 2") (setq zbior (ssget)) (COMMAND "_-HATCHEDIT" zbior "_Properties" "" "2" "") )
and
(DEFUN C:HNGGH () (princ "\nSelect HatchPatterns to change their HatchAngle to 0") (setq zbior (ssget)) (COMMAND "_-HATCHEDIT" zbior "_Properties" "" "" "0") ) (DEFUN C:HNGGT () (princ "\nSelect HatchPatterns to change their HatchAngle to 90") (setq zbior (ssget)) (COMMAND "_-HATCHEDIT" zbior "_Properties" "" "" "90") ) (DEFUN C:HNGGF () (princ "\nSelect HatchPatterns to change their HatchAngle to 180") (setq zbior (ssget)) (COMMAND "_-HATCHEDIT" zbior "_Properties" "" "" "180") ) (DEFUN C:HNGGB () (princ "\nSelect HatchPatterns to change their HatchAngle to 270") (setq zbior (ssget)) (COMMAND "_-HATCHEDIT" zbior "_Properties" "" "" "270") ) ; --- (DEFUN C:HNGGY () (princ "\nSelect HatchPatterns to change their HatchAngle to 45") (setq zbior (ssget)) (COMMAND "_-HATCHEDIT" zbior "_Properties" "" "" "45") ) (DEFUN C:HNGGR () (princ "\nSelect HatchPatterns to change their HatchAngle to 135") (setq zbior (ssget)) (COMMAND "_-HATCHEDIT" zbior "_Properties" "" "" "135") ) (DEFUN C:HNGGV () (princ "\nSelect HatchPatterns to change their HatchAngle to 225") (setq zbior (ssget)) (COMMAND "_-HATCHEDIT" zbior "_Properties" "" "" "225") ) (DEFUN C:HNGGN () (princ "\nSelect HatchPatterns to change their HatchAngle to 315") (setq zbior (ssget)) (COMMAND "_-HATCHEDIT" zbior "_Properties" "" "" "315") ) ; --- (DEFUN C:HNGGHY () (princ "\nSelect HatchPatterns to change their HatchAngle to 30") (setq zbior (ssget)) (COMMAND "_-HATCHEDIT" zbior "_Properties" "" "" "30") ) (DEFUN C:HNGGYT () (princ "\nSelect HatchPatterns to change their HatchAngle to 60") (setq zbior (ssget)) (COMMAND "_-HATCHEDIT" zbior "_Properties" "" "" "60") )
