AutoCAD 2010/2011/2012
Active Contributor
ArmyVet717
Message 1 of 18 (440 Views)
LISP/Routine
440 Views, 17 Replies
11-01-2011 08:31 AM
I am the CAD Coordinator for a telephony company. Some of our projects are very large and complex and require us to calculate the toal length of a conduit run or of aerial fiber to be placed. Is there a tool or something I can use to select a specific layer and have it calculate the total number and length of lines on that specific layer?
I know I can do this for blocks, but I am not sure how to do that for polylines and lines.
Thanks.
Distinguished Mentor
tschau3
Message 2 of 18 (435 Views)
Re: LISP/Routine
11-01-2011 08:55 AM in reply to: ArmyVet717
This will give you the total length of lines, plines and splines.  Type TLEN at the command line.
Active Contributor
ArmyVet717
Message 3 of 18 (428 Views)
Re: LISP/Routine
11-01-2011 09:09 AM in reply to: tschau3
Appreciate it. Next question. How do I get the lisp loaded into CAD?
Active Contributor
ArmyVet717
Message 4 of 18 (422 Views)
Re: LISP/Routine
11-01-2011 09:17 AM in reply to: tschau3
I may not have been clear on my first post.
I figured out to load the lsp file, then tried to use it. It only gives me the total length for the object I selected, in this case a polyline. I was wondering if there was something that would calculate the total length of ALL plines or lines (in this case around 500 individual plines) on a specific layer. List will give me the legth of a sigle line.
Thanks.
*Expert Elite*
Patchy
Message 5 of 18 (415 Views)
Re: LISP/Routine
11-01-2011 09:20 AM in reply to: ArmyVet717
Not LIST command
Use command TLEN
Active Contributor
ArmyVet717
Message 6 of 18 (409 Views)
Re: LISP/Routine
11-01-2011 09:24 AM in reply to: Patchy
I did use "TLEN", it only gave me the length for 1 pline, not the other 499 on the drawing.
Valued Mentor
gjrcmb
Message 7 of 18 (405 Views)
Re: LISP/Routine
11-01-2011 09:26 AM in reply to: ArmyVet717
Are you selecting all the polylines, when the TLEN command prompts you to select objects by typing All or using a window selection?
tschau3
Message 8 of 18 (403 Views)
Re: LISP/Routine
11-01-2011 09:27 AM in reply to: ArmyVet717
I use LAYISO command to isolate the layer, then grab them all with TLEN.
Active Contributor
ArmyVet717
Message 9 of 18 (398 Views)
Re: LISP/Routine
11-01-2011 09:30 AM in reply to: gjrcmb
When I type in "tlen", it simply says "select objects". No option to select "ALL" or anything else. I would like to be able to select 1 line and have it calculate ALL lines on that specific layer rather than selecting each individual line. There are multiple lines with different layers, so a window selects all lines regardless of what layer.
*Expert Elite*
Patchy
Message 10 of 18 (397 Views)
Re: LISP/Routine
11-01-2011 09:30 AM in reply to: ArmyVet717
Tlen, then type in ALL, anything different?
Post to the Community
New Post
Need installation help?
