Can anyone tell me if this lisp routine is right. If it isn't, could you make the neccessary corrections?
(defun C:COMMANDNAME (\ *ERROR ME CE CL)
(DEFUN NEWERR (MSG)
(PRINC (STRCAT "\N*ERROR* : "MSG))
(SETVAR "MENUECHO" ME)
(SETVAR "CMDECHO" CE)
(SETVAR "CLAYER" CL)
(GC) (PRINC)
(SETQ ACADERR *ERROR*
*ERROR* NEWERR
ME (GETVAR "MENUECHO")
CE (GETVAR "CMDECHO")
CL (GETVAR "CLAYER")
(SETVAR "MENUECHO" 0)
(SETVAR "CMDECHO" 0)
(GRAPHSCR)
(DEFUN DTR (A)
(* PI (/ A 180.0)))
(DEFUN RTD (A)
(/ (* A 180.0) PI)
(SETQ IP (GETPOINT "\N 2,5"))
(SETQ EW (GETREAL "\N 6"))
(SETQ E1 (LIST(- (CAR IP)(/ EW 2))(CADR IP)))
(SETQ E2 (LIST(+ (CAR E1) EW)(CADR E1)))
(SETQ E3 (LIST(+ (CAR E2) 6)(+ (CADR E2) 6)))
(SETQ E4 (LIST(CAR E3)(+ (CADR E3) EW)))
(SETQ CP (LIST(+ (CAR E2) 6)(CADR E2)))
(COMMAND "PLINE" E1 E2 "A" "CE" CP "A" -90 "L" E4 "A" "CE" CP E1 "")
(SETQ*ERROR* ACADERR(GC)
(PRINC)
Some things I notice, without detailed evaluation:
(defun C:COMMANDNAME (/ *error* ME CE CL); forward slash, asterisks at both ends of *error*
(DEFUN *error* (MSG); if you're going to do *error* as a localized variable above, define it directly,
;; not with crossed out parts below, and AutoCAD's will be restored when routine ends.
(GC) (PRINC); (gc) does not appear to be defined
(SETQ ;; ACADERR *ERROR*
;; *ERROR* NEWERR
(GRAPHSCR)
(DEFUN DTR (A) ;; these are apparently never used
(* PI (/ A 180.0)))
(DEFUN RTD (A)
(/ (* A 180.0) PI)
(SETQ IP (GETPOINT "\N 2,5")); [not sure what the prompt means]
(SETQ EW (GETREAL "\N 6")); [not sure what the prompt means]
;; I'm not positive without testing, but I think "-90" may need to be in quotes, or it may be read as radians
;; (SETQ*ERROR* ACADERR(GC)
(PRINC)
Also, not "wrong," but you can streamline your variable settings -- you can set multiple variables in one (setq) function as you did with ME / CE / CL:
(SETQ
IP (GETPOINT "\N 2,5"); [not sure what the prompt means]
EW (GETREAL "\N 6"); [not sure what the prompt means]
); end setq
