Looking for a lisp routine that will change one block with multiple tag values; iow, I have one block that will have multiple tag values that need to be changed to new values. I need a routine that will allow me to change the block with the tag value 10-1 to abc, the same block and tag value 10-2 to def, so & sf. The routine will need to search the tag value to determine what the value is and change it accordingly. Also need it to work with a scr file........I had this routine on an external hd that decided it doesn't want to work anymore.
HELP!!
I would recommend searching and/or re-posting here: http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
"........I had this routine on an external hd that decided it doesn't want to work anymore."
Scary.
There are many ways of editing Attributes, check the youtube videos listed in the below link and hope you will find the solution.
