AutoCAD 2010/2011/2012
Member
alangorman
Message 1 of 7 (900 Views)
Lisp routine fails in AutoCAD 2012
900 Views, 6 Replies
01-24-2012 05:21 PM
I am using a fairly old Lisp to generate section arrows, started using this in 2000 and up until 2011. Since we have installed 2012 the routine does not work correctly, after inserting block with attributes instead of bringing up dialogue box it inserts next line of string in to the dialogue box. I have attached lisp routine and blocks can any one help.
Hi alangorman,
Please be sure that you have installed the SP1 for AutoCAD 2012. It works on my machine with the SP installed.
I hope this helps.
Alfred.NESWADBA
Message 2 of 7 (872 Views)
Re: Lisp routine fails in AutoCAD 2012
01-25-2012 06:12 AM in reply to: alangorman
I have not looked to your lisp and sample, but just for this message:
I would guess you just have not set the variables ATTDIA (>>>details<<<) and ATTREQ (>>>details<<<) to the same values as you had them set in your AutoCAD 2011. Verify them and set them accordingly.
- alfred -
Alfred NESWADBA
Member
alangorman
Message 3 of 7 (838 Views)
01-26-2012 05:03 PM in reply to: alangorman
The command attdia is set t 1, switch on, but afetr insertng block DS004, this contains the attributes then rather than bring up dialogue box as previously it inserts INSERT" "ds012 for prompted input automatically, this being the next block required to be inserted.
I can get over all this by removing attributes and using text in block DS004 but I was just hoping there may be a fix.
Best Regards
Alfred.NESWADBA
Message 4 of 7 (827 Views)
01-26-2012 11:02 PM in reply to: alangorman
so your LISP doesn't seem to send/fill the attributes. In this case try to set ATTREQ to 0 before your LISP starts.
HTH, - alfred -
Alfred NESWADBA
Product Support
Albert_Rius
Message 5 of 7 (808 Views)
01-27-2012 07:35 AM in reply to: alangorman
Hi alangorman,
I hope this helps.
Albert Rius
Frontline Technical Support
Valued Contributor
gwhite
Message 6 of 7 (805 Views)
01-27-2012 08:09 AM in reply to: alangorman
take a look at initdia...
used in LISP as
(initdia)
(command "whatever")
to force a dialog box. It works with ATTDEF, ATTEXT, BHATCH, BLOCK, COLOR, IMAGE, IMAGEADJUST, INSERT, LAYER, LINETYPE, MTEXT, PLOT, RENAME, STYLE, TOOLBAR, and VIEW
Member
alangorman
Message 7 of 7 (781 Views)
01-29-2012 06:18 PM in reply to: Albert_Rius
Thanks, installed service pack 1 and all work well.
