AutoCAD 2010/2011/2012
Member
0 Kudos
Post 1 of 4
Lisp automatically loads on new dwg?
567 Views, 3 Replies
03-12-2012 03:30 PM
Is it possible to assign a bunch of 'Lisp' programs to a template, so when I open autocad with my normal template, I also have the 'Lisp' options?
If not, is it possible to load a single 'Lisp' program to load all the rest?
*Pro
169 Kudos
Post 2 of 4
Re: Lisp automatically loads on new dwg?
03-12-2012 05:33 PM in reply to: drafting3
Yes, you can load all your lisps by referencing them inside a aceddoc.lsp file
The ACADDOC.LSP file
5 Kudos
Post 3 of 4
03-19-2012 01:23 PM in reply to: nestly
You can also use the "AP" command, and load all the lisp you want.
Make sure to add them to the contentes to they load at startup.
Cad Blog:
http://geauxcad.wordpress.com/
473 Kudos
Post 4 of 4
03-19-2012 02:00 PM in reply to: drafting3
I would suggest using the "acaddoc.lsp" file and NOT using the startup suite in APPLOAD.
The former is very portable, while the latter isn't - among other things.
