AutoCAD 2010/2011/2012
drafter1411
Message 1 of 5 (351 Views)
Accepted Solution
linetypes
351 Views, 4 Replies
11-13-2012 01:14 PM
Hello everyone, I have created some line types with text, but how do I get the text taller?
this is the linetype:
*COLD_WATER_SUPPLY,Cold water supply ---- CW ---- CW ---- CW ----
A,.5,-.2,["CW",STANDARD,S=.1,U=0.0,X=-0.1,Y=-.1],-.2
I believe the S code stands for size.  You have 2 ways to change the text height:  1)Change the entity's or the global linetype scale, or 2) Change the linetype definition to increase the S value from 0.1 to whatever you want.
Valued Mentor
TrevN
Message 2 of 5 (332 Views)
Re: linetypes
11-14-2012 08:18 AM in reply to: drafter1411
Change the height of your standard text.
drafter1411
Message 3 of 5 (327 Views)
Re: linetypes
11-14-2012 08:26 AM in reply to: TrevN
thanks for the responce, but when I use the line type the text is the same height regaurdless what I set it to.
For example: I stype in style change the text height, then create the line type, but this doesn't have any effect when I use it in a drawing.
Valued Mentor
TrevN
Message 4 of 5 (326 Views)
Re: linetypes
11-14-2012 08:29 AM in reply to: drafter1411
Yes your correct sorry.
As it's a line, the height is detemined by the line type scale.
Change the scale and the height changes accordingling.
*Expert Elite*
dbroad
Message 5 of 5 (325 Views)
Re: linetypes
11-14-2012 09:33 AM in reply to: drafter1411
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
