AutoCAD Forum
Linetype scale
1 REPLY 1
508 Views, 1 Reply
Linetype scale
Hello
i am new in autocad and i have some question (easy question or maybe idiot question)
i sketch a some drawing a scale 1:1
i make a block in scale 1:1 , i put a axis in block
if i modify a scale to 1:2 or 1:5 or 1:10 how modify a linetype scale (what is the factor for scale 1:2 is .. linetype scale 0.5 ?)
i am talking for plot
thanks
1 REPLY 1
Moshe-A
for plotting from model space you should set ltscale to be the same as your plotting scale
for example:
plot scale is 1=10?      ltscale =10
if the dash propotion is not suitable? try replacing it with the same linetype from the other lin file
moshe
”Boost
