AutoCAD 2010/2011/2012
Member
calembequeta
Message 1 of 8 (374 Views)
Line weight
374 Views, 7 Replies
10-02-2012 05:06 AM
Hi
I'm experience chanllenge in editing The line in my dwg. The line weight on my drawing once printed, is not The same as I have set up on my pen setting style. I have tried The pedit function by increasing The line width to 0.6mm but nothing change on my preview window. It looks like there is an issue with reference editing. Any help guys?
Regards
Changing the thickness of a polyline lets you establish its width in model units, not paper units. Setting lineweights as others have explained will affect the width in paper units if the plot style is set up to use object lineweights. Otherwise the plotstyle governs the lineweights on paper.
This used to be the case, but upon confirming just now by trying it here you *can* use a ctb file *and* pline widths to modify your plotted lineweights
(here's what my plot box settings look like, if that makes any difference)
pendean
Message 2 of 8 (372 Views)
Re: Line weight
10-02-2012 05:10 AM in reply to: calembequeta
You can't use both a plot style table setting and a Pline width setting: they cancel each other out.
Chose one, or the other, and stick with it.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
calembequeta
Message 3 of 8 (366 Views)
Re: Line weight
10-02-2012 05:30 AM in reply to: pendean
Hi Dean
I have tried both separately but it didn't work. I usually use one pen setting style for all my drawings and it works. This specific one is not working with my pen setting or with pedit line width.
*Pro
ampster
Message 4 of 8 (358 Views)
Re: Line weight
10-02-2012 05:34 AM in reply to: calembequeta
try the lineweight command.  In the window that pops up, check what the option "Display Lineweight" is set to.  If it's enabled, disable it or vice versa.
HTH
pendean
Message 5 of 8 (352 Views)
Re: Line weight
10-02-2012 05:40 AM in reply to: calembequeta
If you want, post the file and it's plot style table and let's all have a look.
dbroad
Message 6 of 8 (309 Views)
Re: Line weight
10-03-2012 05:33 AM in reply to: calembequeta
Distinguished Contributor
pkolarik
Message 7 of 8 (306 Views)
Re: Line weight
10-03-2012 06:14 AM in reply to: pendean
Member
calembequeta
Message 8 of 8 (297 Views)
Re: Line weight
10-03-2012 06:29 AM in reply to: pkolarik
Thank you guys, got it right.
Regards
