Hi everyone,
I'm new at this forum and I also don't have many experiences on Autocad. For my studies as an urban planner I have to construct a cityplan. For this I should use some existing borders. I get this bordes out of a (own) GIS solution (.dxf). Now when I try to work with this file with Autocad 2010lt I am not able to change the lineweight of all lines (polylines, arcs ...). But I can change the Typ. If I draw a new line in the same layer, the new lines get the propertys of the layer, the existing ones not. I don't understand why it doesn't work. Maybe there are some major problems.
Hopefully someone can help me.
Thanks a lot
Leander
Solved by pendean. Go to Solution.
Entities show color/lineweight/linetype of the layer only when their object'property is set to "byLayer".
When a line is assigned to layer "RED" (layer-color is set to red), but the line is shown in green then the line has the color set to "green" and not to "byLayer".
What you can do now for your existing objects: select them all, and in the property window change their color and lineweight and linetype to "byLayer".
As long as that are no block-insertions this should work.
- alfred -
Hi Alfred,
thanks for your answer, but I allready tried every thing like this. So all options with byLayer or the other direct ones. I have the feeling all lines in this projects are not realy lines or there is something damaged. If I look at the propertys everything is polyline but it looks like there are no interior lines inside the linecontour ( maybe there existing just the hatching). If i draw a new line, and I select them, there is some kind of interior line.
The option with "show lineweight" is also knowen.
Thanks if someone can help me. I can also upload the .dxf file.
Then please upload the drawing (or at least a reduced set of the drawing with some of the objects not showing lineweights).
BTW: do you speak about polylines and have they set a polyline-width?
- alfred -
Hmm I'm not realy sure.
Maybe this example shows, what I mean. Hopefully this problem is not to stupid.
Thanks for your help.
Very Thanks 🙂 As I told, I'm not that expirenced, but the global width was my mistake. I changed this now, and I'm happy. By the way, is there a parameter in some global settings to change ist? I done it now, by selecting everything and change it by polyline in the pop up setting menu.
Anyway, thanks a lot. (y)
