AutoCAD 2010/2011/2012
Member
ldremml
Message 1 of 8 (18,689 Views)
Line type not showing up properly in paper space
18689 Views, 7 Replies
01-27-2011 11:43 AM
My "center" line shows up fine in model space, but just solid lines in paper space.  What am I doing wrong?
Leah
Active Contributor
rmitchler
Message 2 of 8 (18,681 Views)
Re: Line type not showing up properly in paper space
01-27-2011 12:15 PM in reply to: ldremml
Others have different set up, but I typically set the following to 1
ltscale=1
msltscale=1
psltscale=1
You can also look at your annotation visibility icons at the bottom of your screen
Robert
Member
ldremml
Message 3 of 8 (18,666 Views)
01-27-2011 01:03 PM in reply to: rmitchler
Hi Robert,
  I changed them back to 1 and it showed up in p.s. good on the longer lines, but the short ones were still solid, so I changed it to .5 and it worked great.
Thanks.....
*Pro
Modman_4
Message 4 of 8 (18,656 Views)
01-27-2011 02:06 PM in reply to: ldremml
1. Set LTSCALE, PSLTSCALE, MSLTSCALE & CELTSCALE all to 1
2. In paperspace, draw examples of the standard linetypes that came with AutoCAD (for example, hidden, hidden2 and hiddenX2)
3. Test-print the linetypes at 1:1 scale in paperspace, compare them, and select the ones that you wish to use.
4. In modelspace, set CANNOSCALE to 1/4" = 1'-0". It is found on a list on the taskbar, next to an icon of the end of a drafting scale. The default scale is usually 1:1. Pick 1/4" = 1'-0" from the list.
5. Now select your hidden linetype and start drawing a sample.
6. Switch back to the paperspace tab and create a viewport. Double-click inside it and zoom in to your example. Then double-click outside the viewport to return to paperspace. Click on the viewport to highlight it, and change its scale to 1/4" = 1'-0". You should see the dashed line in the sample, similar to how it shows in modelspace.
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
Member
ntodd
Message 5 of 8 (14,957 Views)
01-10-2013 07:56 AM in reply to: ldremml
Model and Paper space are drawn 1:1 scale, but linetype shows differntly in model space. LTS is 1, PSLTSCALE, MSLTSCALE, CELTSCALE are (1). Any thoughts?
New Member
norsman333
Message 6 of 8 (14,946 Views)
01-10-2013 10:11 AM in reply to: ldremml
Try going into a viewport,
linetype manger
check use paperspace units for scale
regen might have do do it again
good luck hope this helps
Member
ntodd
Message 7 of 8 (14,941 Views)
01-10-2013 10:25 AM in reply to: norsman333
Thank you for your help. For some reason it decided to work after half an hour, without me doing anything, but I will bear your advice regarding linetype manager in mind. This drawing is saved down from Acad 2012, so it may have had something to do with it.
New Member
norsman333
Message 8 of 8 (14,823 Views)
01-15-2013 06:07 PM in reply to: ntodd
Your welcome, But keep in mind; cad drawings don't decide to work by themselves
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
