AutoCAD Forum
Line stretching problem
4 REPLIES 4
mtoxqui
2358 Views, 4 Replies
So when i try to stretch and snap a line, it randomly goes to another point in the drawing. The point is always the same and I have noticed this doesnt happen if Object Snap is turned off. Any suggestions?
I have resetted the profiles and doing so fixed the problem, however i would like to know if there is a setting that could prevent this from happening again.
In the following videos you can see the user trying to stretch a line into a nerby intersection. Instead, the line stretches towards a far away point.
http://youtu.be/FxWV2alHtM0
 http://youtu.be/Rk-Z_86Xfyo
Thank you!
4 REPLIES 4
Patchy
in reply to: mtoxqui
UCSICON   Turn it ON, show us the current UCS you're using.
mtoxqui
in reply to: Patchy
Command: UCSICON
Enter an option [ON/OFF/All/Noorigin/ORigin/Selectable/Properties] <ON>: ON
Command: UCS
Current ucs name: *NO NAME*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis]
<World>: *Cancel*
Patchy
Command: UCS use W
Command: Plan use C
mtoxqui
in reply to: Patchy
Perfect
Thanks!
”Boost
