AutoCAD Forum
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Limited rotation in 3D
2 REPLIES 2
tmccar
432 Views, 2 Replies
I have drawn an end view of a steel duct in the XY plane which I have extruded along Z. I wanted to look at it in 3D from an approximately isometric viewpoint. So I rotated the view using Shift-click, but my rotation options seem to be limited. It seems as if there is a "lock" on any horizontal rotation and I can only rotate vertically. I think it's related to the pivot, but I'm not sure.
2 REPLIES 2
GrantsPirate
in reply to: tmccar
Try using 3DFORBIT to see if that works for you.  Also try 3DORBIT.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
tmccar
in reply to: GrantsPirate
Yes, that works better, thanks
ā€Boost
