I have drawn an end view of a steel duct in the XY plane which I have extruded along Z. I wanted to look at it in 3D from an approximately isometric viewpoint. So I rotated the view using Shift-click, but my rotation options seem to be limited. It seems as if there is a "lock" on any horizontal rotation and I can only rotate vertically. I think it's related to the pivot, but I'm not sure.
Solved by tmccar. Go to Solution.
Try using 3DFORBIT to see if that works for you. Also try 3DORBIT.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
