hi
I am trying to set up a drawing to show the levels of a plot that i am working on. I have imported the strings with x y and z coordinates but when i orbit around the drawing it is flat. How do i set it up so that when i orbit around it shows the differences in levels visually? The plot contains many batters and ponds so there is a big difference in the levels.
Cheers
welcome @forums.autodesk.com!
Sorry to not understand that, how do you import "STRINGS" or what are "STRINGS" for you (maybe it's me just not understanding the word in that context)?
If you have geometry objects on different elevations (Z-coordinates) you might see them in different "heights" when using orbit.
If you want to create geometry on different elevations you can set the UCS to the z-value for the specific level you want to work and draw your level-specific geometry.
If you have a vertical product like AutoCAD Architecture or MEP you will find predefined functions for level-handling.
HTH, - alfred -
