AutoCAD 2010/2011/2012
New Member
0 Kudos
Post 1 of 3
Leader Text Thickness
382 Views, 2 Replies
10-04-2012 02:35 AM
I am currently using AutoCAD 2011LT. When I add a leader sometimes the text appears fine and sometime the text appear to go bold, I tried retyping the text but it appears to be luck of the draw as to when it happens. I don't have a problem with this showing up on the screen but it transfer to prints on both paper and PDF.
Please could someone tell me if this a bug and is there something I can do to fix it?
1,218 Kudos
Post 2 of 3
Re: Leader Text Thickness
10-04-2012 02:49 AM in reply to: dfrowde
easiest option would be to upload the drawing that shows a bold text whereas the text-style is not  set to bold and (in case of SHX) the layer is not set to a big lineweight (and the sysvar LWDISPLAY is ON).
- alfred -
Alfred NESWADBA
1,605 Kudos
Post 3 of 3
10-04-2012 06:33 AM in reply to: dfrowde
Where are you "adding" it from? Lanuch the MLEADER command, or a copy/paste from another source?
I bet you use TTF Windows fonts too, problem does not exist with SHX stick fonts from Autodesk: your Mleaders have a Z elevation height assigned to them if that's the case.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
