AutoCAD Forum
Layout problems
5 REPLIES 5
bleuetrose
515 Views, 5 Replies
Layout problems
I have big problems with the size of the manu and name of the layouts . They are too big and I cannot make them smoler. I restart the computer many times, but that nothing change. What I can do to be show me smoler?
Thank you in advance!
5 REPLIES 5
bleuetrose
in reply to: bleuetrose
I tried to fix with the menu  as shown below, but nothing from this menu fixed the problem. I have done searches in Internet, but I haven’t find solution until now. This big size is the same regardless of which drafts I open with AutoCAD Smiley Indifferent
bleuetrose
I am sorry, there is a typing mistake, the word “smoler” should be “smaller” .
Ajilal.Vijayan
If above suggestion doesn't work, try to reset this to 100%. Then restart your computer.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
bleuetrose
Thanks for the advice both of you. For a long time I was looking for such a solution. What Mr Edwin Prakoso explained to me, that finally  solve my layout problems with the size. Now everything is fine. Thank you very much! 🙂
”Boost
