AutoCAD 2010/2011/2012
doni49
Message 1 of 11 (511 Views)
Layout and Model Tabs show SOMETIMES (I want them always)
511 Views, 10 Replies
01-03-2013 02:56 PM
I have checked Options>Display>Display Layout and Model Tabs.  It is ON.  Yet they seem to only randomly show up.
More often than not, they're NOT SHOWN.
I really don't like the new way of changing between layouts and want to use the tabs.  Anyone have any ideas?
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Customization
Other Helpful links:
My File is too large to post or I can't post it due to privacy issues!
When I said "minimized" I meant by using the middle button where the arrow is pointed to in my pic.  Not minimized as in docked at the bottom of the AutoCAD window which the left button does.
Your last posted pic shows the drawing window minimized but centered in the AutoCAD window.  The tabs are displayed.  Your first pic showed the same thing, only the drawing window bottom, (where the tabs are), was below the command line.  Therefore, you couldn't see the tabs.  If you would have moved the drawing window up they would have been visible again.  By maximizing and then minimizing, the drawing window centered itself in the AutoCAD window and shows everything.
I hope that explains it a little bit better.
doni49
Message 2 of 11 (477 Views)
Re: Layout and Model Tabs show SOMETIMES (I want them always)
01-09-2013 08:34 AM in reply to: doni49
Don Ireland
Forum links:
Civil 3D General
Valued Contributor
Patchy
Message 3 of 11 (474 Views)
01-09-2013 08:46 AM in reply to: doni49
Do you run any add-on application?
If you do, look for the line:
(setenv "ShowTabs" "0")
doni49
Message 4 of 11 (452 Views)
01-11-2013 06:48 AM in reply to: Patchy
I don't know of anything running.  But I just ran into one instance where the tabs aren't showing up.  I did getvar on ShowTabs.  It's set to 1 currently but yet I have no tabs.
Don Ireland
Forum links:
Civil 3D General
*Pro
steve216586
Message 5 of 11 (450 Views)
01-11-2013 06:56 AM in reply to: doni49
When your Layout and Model tabs "disappear" is the drawing window minimized?  Not the AutoCAD window but just the drawing window.  If you maximize the drawing window do the tabs "reappear"? See attached for pic.
Patchy
Message 6 of 11 (443 Views)
01-11-2013 07:06 AM in reply to: doni49
I see it now, your screen is minimized.
doni49
Message 7 of 11 (432 Views)
01-11-2013 07:36 AM in reply to: Patchy
Hmmm.  I wasn't (and I'm still not) too sure what you were talking about.  But my screen wasn't minimized.
BUT.......
I maximized my current drawing within the Acad window and the tabs appeared.  Then I "restored" the drawing to its previous state and the tabs STAYED.  And as if that didn't muddy the waters enough, I tried checking the value of that ShowTabs variable again.  It's NIL now.
Don Ireland
Forum links:
Civil 3D General
*Pro
steve216586
Message 8 of 11 (428 Views)
01-11-2013 07:42 AM in reply to: doni49
Patchy
Message 9 of 11 (426 Views)
01-11-2013 07:44 AM in reply to: doni49
Not "Getvar"
doni49
Message 10 of 11 (394 Views)
01-15-2013 06:54 AM in reply to: Patchy
Setvar is how you set the variable.  Getvar shows what the variable is currently set to.  That's what I was using it for.  But it's solved now.
Don Ireland
Forum links:
Civil 3D General
