AutoCAD 2010/2011/2012
0 Kudos
Post 1 of 8
Layers question
317 Views, 7 Replies
02-29-2012 03:46 AM
When I copy and paste with a base point an object from another file, the objects carry over the layer(s) the object is on. Now I take these objects and place them on the correct layer, already existing in the file. When I purge the file the layers will not delete. When I do a view layers, the layers that where copied and pasted still show geometry on that layer but if I turn every thing off but those layers, nothing shows on the screen. How do I handle this? Thanks
The fix I used for this. Go to Layers Properties Manager, select all, unlock, unfreeze and turn all layers on. Lock the layers you don't want, do a 'copy with base point', pick base point (0,0). When selected open another window and do 'paste as block' at 0,0 point. Check layers properties manager to see if unwanted layers are still there. When satisfied explode block and save as existing file. This cleared my problem. Thanks
128 Kudos
Post 2 of 8
Re: Layers question
02-29-2012 04:28 AM in reply to: ut2897h
Have you tried save the file and re-open it to see if you can purge?
3wood
CAD KITS
312 Kudos
Post 3 of 8
Re: Layers question
02-29-2012 04:34 AM in reply to: ut2897h
does the geometry you are pasting include block entities?
*Pro
169 Kudos
Post 4 of 8
Re: Layers question
02-29-2012 05:17 AM in reply to: JGerth
Yep, that sounds like blocks with layers assigned to the objects inside the block.
Product Support
30 Kudos
Post 5 of 8
Re: Layers question
03-02-2012 05:58 AM in reply to: ut2897h
In case the previous suggestions do not help, please upload your files so that we can have a look.
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
Product Support
30 Kudos
Post 6 of 8
Re: Layers question
03-06-2012 09:26 AM in reply to: ut2897h
Did you manage to sort this one out?
Cheers,
Luciane
Active Member
0 Kudos
Post 7 of 8
Re: Layers question
03-06-2012 02:20 PM in reply to: ut2897h
try tying -purge and then all and see what happens.
0 Kudos
Post 8 of 8
Re: Layers question
03-27-2012 06:04 AM in reply to: ut2897h
