AutoCAD Forum
Layers are changing to current layer....
3 REPLIES 3
brandih
475 Views, 3 Replies
I'm having an issue with AutoCAD and I'm not sure if it's a glitch or a command I accidently used. I use AutoCAD 2010.
When selecting an object, the layer of that object automatically changes to the current layer but keeps the original color.
For instance, If my current layer is "0/White" and I click on an object that's on layer "LINE/Red," it will change that object's layer to "0/Red."
I'm grateful for ANY help. I'm pulling my hair out on this one....
B
3 REPLIES 3
Patchy
in reply to: brandih
Layer LINE/Red
so you're not using color bylayer?
parkr4st
LAYCUR command appears to be working and as Patchy asked not color bylayer but set to color red or white?
brandih
in reply to: parkr4st
My "Pickfirst" was set to 0, rather than 1. Thanks for the help...
B
”Boost
