AutoCAD 2010/2011/2012
GrantsPirate
Message 11 of 18 (1,255 Views)
Re: Layer States VP Freeze doesn't work anymore
06-01-2011 12:21 PM in reply to: Eycki
I am able to set all on in MS, go to Layout blue and set LS Blue, go to Layout red and set LS red.  Each layout is displaying properly, Layout Red shows just red, Layout Blue shows just blue, Model layout shows all.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
pendean
Message 12 of 18 (1,248 Views)
06-02-2011 06:10 AM in reply to: Eycki
See if this other thread will help:
http://forums.autodesk.com/t5/AutoCAD-2012/Saving-layer-states-in-drawing-as-separate-viewport-overr...
Your recent file works just fine, like the first one here. All in 2012, no manual editing of LAYER command is taking place.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Eycki
Message 13 of 18 (1,233 Views)
06-07-2011 02:19 AM in reply to: pendean
I think I will need to capture a movie to show.  I started from Scratch again in AutoCAD 2012.  I created a Layer State in model space with the some layers frozen.  When I restore this LS in the layout view (in an activated viewport), the Layers that were frozen should be shown as VP freeze in the Layer Manager.  But this is not happening, its just frozen, and thus also turned of in any other viewport and model space. Im about to give up :smileysad:
Eycki
Message 14 of 18 (1,230 Views)
06-07-2011 03:36 AM in reply to: Eycki
Attached een screenshot of my layers when I just restored a Layer State in an active VP.  The Layers are just frozen and not VP frozen.
Eycki
Message 15 of 18 (1,195 Views)
06-23-2011 05:48 AM in reply to: Eycki
Finally I found what the problem is.  Hope that AutoCAD fixes it soon.  Restoring a Layerstate from the Dropdown in the ribbon is not doing the same thing as restoring it from the Layer States Manager.  When restoring it from the LS Manager it does perfect and my layers get into VP freeze.  When doing  it from the dropdown the layers will get frozen (which reflects model space and other layouts). In AutoCAD 2011 it was working both for me, but in 2012 the dropdown LS restoring seems not to work good.
neaton
Message 16 of 18 (1,192 Views)
06-23-2011 06:08 AM in reply to: Eycki
In the commands LAYFRZ and LAYOFF there is a Settings option for how AutoCAD treats viewport selections: either freeze layer or turn it off. My guess is that one of these is set different than in your previous version and causing the difference.
Nancy
Eycki
Message 17 of 18 (1,190 Views)
06-23-2011 06:34 AM in reply to: neaton
I just had a check and the settings are the same.  Both are on VP freeze.
http://withoutanet.typepad.com/without_a_net/2010/02/restoring-layer-states-with--layer.html
Active Contributor
Kamasop
Message 18 of 18 (1,044 Views)
10-14-2011 07:07 AM in reply to: Eycki
i just want to add, that i have problems too.
I have yet to go through the proposed solutions, so it might be something totally simple (like a checked box) or not...
just saying...
