AutoCAD 2010/2011/2012
Active Member
nina.rihn
Message 1 of 5 (1,317 Views)
Layer Manager font error
1317 Views, 4 Replies
05-07-2009 08:09 AM
My boss is unable to open the layer manager; he gets the Unhandled Exception error message: "Only True Type fonts are supported. This is not a True Type font." This occurs on a blank project or even on an existing one. this was happing with AutoCAD 2009 and now is still happening on his new install of 2010.
Any idea how why this is happening or how to fix it?
*Tony Tanzillo
Message 2 of 5 (1,317 Views)
Re: Layer Manager font error
05-07-2009 04:38 PM in reply to: nina.rihn
This is a system problem, and usually indicates that required fonts are
missing.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:6178908@discussion.autodesk.com...
2010. Any idea how why this is happening or how to fix it?
Active Member
Tekcon13
Message 3 of 5 (1,317 Views)
05-08-2009 04:48 AM in reply to: nina.rihn
I had this error and Autodesk Support traced it to my display settings.
I was using Windows Classic Style in Windows XP (Display Properites->Appearance->Windows and buttons). When I switchd to Windows XP Style the Layer Manager opened.
Note that this problem only happened to me with the new modeless Layer Properties Manager ( LAYERDLGMODE = 1 ). I did not get this error when using classic layer manager ( LAYERDLGMODE = 0 ).
Active Member
nina.rihn
Message 4 of 5 (1,317 Views)
05-08-2009 10:22 AM in reply to: nina.rihn
Thank you so much Ultrablue!! I had my boss change his LAYERDLGMODE to 0 and it worked and made him very happy! I also told him about the Windows XP style in case he ever decided he wanted to use the modeless menu.
*Tony Tanzillo
Message 5 of 5 (1,317 Views)
05-08-2009 10:23 AM in reply to: nina.rihn
The problem isn't related to using the Windows classic display style
(I use it exclusively without problems).
The layer properties manager is trying to use one of the fonts that is
configured via Control Panel (possibly the font used for desktop icons),
which can be a non-TrueType/ClearType font, and that's when it happens.
